I run into an inconsistent result when working with Change Request (CR) objects in Director. I attempt to navigate to the Markup (MU) Document via the Progress section on the CR but Director instead opens the Affected Document. This isn't always the case and I click in the same place every time (see screenshot). About half the time the MU opens when double clicked, the other half the Affected Document opens. Is there a trick or fix to make this open the MU consistently?
Thank you, Patrick
Hello Patrick,
I was able to replicate your issue on eB version 15.6. It is bug and a workaround would be to click on first part of object name (see screenshot – clicking on marked areas will always open the right object).
I’ve checked version 16.3 and this feature works better but not perfect. I will create SR and will raise this issue as a bug internally.
Answer Verified By: Carma De Villiers
