Error dropping pdf on eB icon when adding new object to template
Error dropping pdf on eB icon when adding new object to template from middle pane drop-down.  Works when you go through left pane, select template and create instance, or if document object is already created, you can drop pdf on eB object icon in right hand pane.
Error:
"Unable to create new instance from the template you specified.  Conversion failed when converting the nvarchar value '0|9' to data type int."
