A user who just updated to IE 11 is experiencing difficulty selecting the turtle without having to double-click twice on the turtle icon. She did not experience this issue when selecting the turtle with previous versions.
Has anyone else seen this issue?
Thanks!
Hi Brayan,
I had tested this issue at our end.
This seems to be IE 11 causing this issue on windows7/windows server 2008r2 as it works on windows 8/ Windows server 2012 with IE 11.
Below is the link which has a work around stackoverflow.com/.../double-click-event-not-working-on-windows-7-ie-11-when-control-does-not-have-f Hope this helps.
Regards, Deepti
Hi Brayan, The workaround reg fix provided should resolve your issue. After making the changes from reg just add the eBweb link to compatibility view settings from the eB server. This will resolve your issue for users as well.
Here is the wiki with the steps to fix this issue
http://communities.bentley.com/products/assetwise/assetwise_platform/w/wiki/24930.double-click-on-add-turtle-ie-11-doesn-t-works-for-drop-zone
Let me know how it goes. Regards, Deepti
Answer Verified By: Manav
