Is there a planned fix that will allow users to Approve Documents in Bulk using the Basket even if the Basket contains some Documents that have Mandatory Attributes that have no Data Associated and some Documents that are able to be Approved?
Currently an error is received that states that "I'm sorry, an error prevented the process from completing".
We have requested in the past that a fix be provided that allows the Documents that are ready to be Approved to receive Approval and the Documents that need data in Mandatory Attributes will result in an error that does not allow them to be Approved.
The ticket numbers submitted in the past were 8001461596 / TS9671.
Thank You!
Bryan
Hi Brayan,
I have checked this issue was reported in the past as it has been closed as its working as designed. If the bulk approval basket contains few documents with mandatory attributes then it should be filled in first then you bulk approve it will work.It is working in correct way by pointing out to fill in the mandatory attributes before you approve the object.Regards,Deepti
