Bentley Communities
Site
Search
User
Site
Search
User
Product Communities
AssetWise
AssetWise ALIM
Cancel
AssetWise ALIM
AssetWise ALIM Forum
pull pictures into crystal report
Sign In
State
Verified Answer
Replies
Answers
Subscribers
23 subscribers
Views
Users
0 members are here
eB Document
eB 15.5.1
eB
Files
Offline
Alex Talbott
over 8 years ago
Has anyone ever pulled pictures being stored in eB into a crystal report?
0
Offline
Carma De Villiers
Mon, Jul 11 2016 3:28 AM
Hi Alex, apparently this can be done. It seems to be quiet an effort to do this. What is the reason for adding a picture to you crystal report?
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Reject Answer
Cancel
0
Offline
Carma De Villiers
Fri, Aug 19 2016 4:41 AM
Hi Alex,
Has this issue been resolved? If so, could you please close the issue by selecting "This helped me" and "Verify Answer". If not, please let me know so I can follow up on this issue.
Carma
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Reject Answer
Cancel
0
Offline
Alex Talbott
Fri, Aug 19 2016 8:43 AM
in reply to
Carma De Villiers
The reason is quite extensive in nature but the short of it is the business user has requested it. Do you all have an example or can you point us in the general direction of the process. Thanks for your help.
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
0
Offline
Carma De Villiers
Mon, Aug 22 2016 12:16 AM
in reply to
Alex Talbott
Hi Alex,
I will speak to our developer and get back to you!
Carma
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Reject Answer
Cancel
0
Offline
Carma De Villiers
Tue, Aug 23 2016 3:11 AM
in reply to
Alex Talbott
Hi Alex,
What version of Crystal Report are you using?
The picture you want to add to Crystal Report, must it come from eB?
Do you want to add it manually from a folder or must it be exported from eB to Crystal Report?
I need this info for our developer to write a instruction for you.
Carma
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Reject Answer
Cancel
