We have a serious security issue. In eB v15.6.1 users can modifiy/edited any realtionship in approved documents, even Cross References,
We need to avoid this ASAP, thanks a lot,
Sebastian.
This feature is controlled in relationship class by option called 'Controlled By'. If it is set to 'Not Applicable' then using this relationship class you can relate approved documents or drop this relation between approved documents. If this option is set to 'Both' then you won't be able to create/drop relation using this relationship class when one of the documents is Approved. Options 'Left''Right' will allow to use relationship class for relating objects depending which objects is Approved.
Hope this helps
Answer Verified By: Sebastian Fernandez Pacheco
