Projectwise connector - new revisions
When a new revision of a document is pushed through the projectwise connector, it does not inherit the relationships of the previous revision, already in eB. Is it possible to change the connector so that these relationships are inherited?
Kind regards,
Catherine
  • Hi Catherine,
    I am trying to understand the requirement right now. You created a document in projectwise and pushed it to eB. So now a document is in eB.
    Now made some changes and put some relationships with the document in projectwise, and the changes you made not reflecting in eB document when you again try to push it through connector? Am I right?
    When you created a new revision, are the relationships inherited successfully?
    Manav B.
  • Catherine,
    Did some more findings for Attribute/relationship mapping.
    Well currently a certain level of attribute mapping exists that allows importing ProjectWise attribute data onto eB document attributes there is no functionality to create more advanced relationships.
    When a document is registered custom logic needs to run to achieve this, an EventHandler for the OnObjectChanged eventhandler called cr_projectwise_registered will be added. It triggers when a document is changed and the document is linked to a ProjectWise item.
    To implement the same, you need to contact the Professional Services team.
    Manav B.
    Answer Verified By: Deepti Patil
