Where is the file size stored in the eB database?
I have created a report that lists the file size.
START WITH File SELECT Id, FileSize, Name WHERE Document.Class.Code = @DocClass
Because I am trying to determine the file size of all of 600,000 files for a doc class I am unable to run the report and get a complete list. I am looking for a db query to run to determine this information but I can't find the correct field and table.
I thought it might be in DOC_SOURCE which has the fields ORIG_FILE_NAME AND DOC_SIZE BUT DOC SIZE IS BLANK.
Can someone point me in the correct direction? Thanks for your help.
Answer Verified By: Alex Talbott
Thank-you for updating the thread with your findings! It is useful for other community users with the same question.
