eB ProjectWise connector - ProjectWise multi-value attributes?
Hello.
Can I map a multi-value ProjectWise attribute to an eB multi-value attribute?
Will eB recognise it as multi-value and populate its own field accordingly?
Stuart.
Parents Reply
  • HI Stuart,
    If you email me your test results with the configuration details in PW and eB (including version used on both ProjectWise and eB), I would like to find the Enhancement Request using your “use case” on your behalf.
    Note: your name seems to be very common in our database. If you email (john.lee@bentley.com) me, please include your contact information and the company this use case is referenced.
    John
