We can't make a search and display different related objects in a single line.
I mean, when you search for documents and you want to display a relationship, let's say Locations for example (It happens with any kind of relationship) and the document is related to 4 locations you will get 4 lines as a result, one for each location.
To avoid this we tried to use CASE syntax but we cannot make It work as expected. It's working but is not showing 1 line for the document, It's still showing 1 line for each location related to the only one document matching the search criteria.
Please review the image below and advice ASAP, thanks!
Hey
To combine duplicate results you will need to use web and there is option called 'Combine duplciate record data' below result pane.
This feature is not available in Director and there is no way to auto enable it in WEB UI.
