I am trying to import Virtual Item to Virtual Item Relation ship through Staging table (table name - stage_relationships) but getting below status message in "stage_load_status_arc" table
Error - Based on provided specifics, the Left Object was not found. Code = 86 Middle: Rev:
below is a loading data format of staging table - stage_relationships
Note that left (86) and right (86-20) objects specified in above data are already present in EB as Virtual Item and they don't have "Middle" and "Revision" Fields in VITEMS table.
How to resolve this issue and load relationship between virtual Item and Virtual Item through staging table ?
Kindly reply ASAP as this needs to be resolved on priority basis.
Thanks & Regards
Chirag Shah
Using above mappings, I am getting error in "stage_load_status_arc" table that "Error - Based on provided specifics, the Left Object was not found. Code = 86 Middle: Rev: " Means it is not able to locate virtual Item named "86" but it is already present in EB Director and I can find it in "VITEMS" database table too but it (Virtual Item) doesn't have fields named "Middle" or "Rev". then how can I specify its value in "left_object_middle" & "left_object_rev" fields in mappings above ?
Answer Verified By: Carma De Villiers
