I am trying to update an auto-filing folder that was created in version 14.6.1 and uses SQL. In order to update these types of folders in the past, we have used a provisioning spreadsheet. Until this week, we have not had to update any queries since upgrading to 15.6.1. I am running into an error when I try to import the updated query. I am able to do an export of all Folder Searches, find the folder, and modify the SQL. However, when I go to Import the update, I get an error stating that the "folder does not exist". If it was able to export the folder, why can it not import?
You can see the folder highlighted below in the export list:
Now you can see the error message that I keep receiving:
Also, I had to modify the original SQL that was used for the export. I am not sure if this has anything to do with the failed import. The modified and original SQL is below:
This is the original SQL. I highlighted the part that I removed.
And here is the new SQL that I used for export:
Answer Verified By: Carma De Villiers
