Copy Work Order Template
How can I copy a work order  template from existing templates?
  • Hi Mohd,
    You can copy from an existing template.
    Firstly start the new Class and go to Template.
    Select "from existing"
    Add the existing template number and the rest of the detail.
    Answer Verified By: Mohd Jimmy Ismail
  • On the "Point to existing object" add the template name and description and the mask and proceed
  • I have also attached a document that explains the copy concept.
