We want to enter information about, tags, items and serialized items and then be able to report the out. Is there any documentation, with examples, showing how to configure the items?
I have some sample data entered, but I can't find the correct options to get a good report out, so I am wondering if I am not using the appropriate fields.
Using version 15.5.1.
You can search the related Tag with the same Serialized Item only. Instead, you can start your search with Tag and check where all it is used.
Answer Verified By: Carma De Villiers
