Hi Bentley and the forum,
Do you have a provisioning spreadsheet with tabs for relationships for eBv15.6.1 please?
If I wanted to create relationships between documents with other documents in bulk would I use the provisioning spreadsheet and how please (which tabs? is it just the relationship one?)?
Can you bulk relate documents to virtual item structures? If you can, can you do this via the provisioning spreadsheet or can you do this via the bulk import method? If it's via the provisioning spreadsheet, please could you let me know which tabs to use and which order. If it's the bulk import method, please could you provide an example ini file?
Many thanks, best regards,
Julie
Answer Verified By: julie_beck
