Bulk Import Duplication
A user has tried to import documents using the bulk import utility. Somehow, eB appears to have tried the import twice. The import container has 2 success and 2 error logs.
This has caused an issue, as the documents were added the first time, and then any that had any kind of error (even when the document was created anyway) were added again (albeit the document number update wasn't successful so just the default number was given).
Do you know how this has happened?
Kind regards,
Catherine
