copying a folder structure in Director - can't select destination
Using version 15.5.1
I want to move some folders so my plan was to use the copy function and then delete the original folder. I want to do this in Director so I can select to retain the security from the original folder. There is no option to retain the security in the web folder copy, unless I missed it?
When I try to select the new folder location and I click on "Other Folder"  it just spins and then times out. I can select "My eB" as a destination with out a problem, and I can select the destination location ok in the web client.
