intention is to add non controlled attributes on a TAG.
In this case it is possible to modify this TAG attribute on the PLANT TAG.
BUT when having multiple prototypes of it the system wil erase your modifications on the PLANT tag when merging back from 1 of the PROTOTYPES.
What can we expect?
- behaviour
- what happens with prototypes
- what when merging back from proptype to mastertag?
The behavior is whatever is in the prototypes is merged into the master tag.So, If you already have Prototypes created before the additional tag attributes were added then the only way is to add the additional attributes to the Prototypes before merging the Prototype into the mater tag.
very poor behaviour...i expected some more configuration options.
Answer Verified By: Carma De Villiers
