Session ID variable issue.
Hi, I'm trying to reference the Session Id in an Attribute Lookup Query to bring back the current 'user' and 'organisation'...I'm using $Session.Id for the variable but it's not recognizing it. Any ideas? Am I wasting my time?
Paul
  • Hi Manav,
    I'm building the query in SQL Server. I can see what I'm doing there and grab the correct tables. Then I'm transferring the code to the eQL panel. I thought I was using eQL accepted code though? Do you think not?
    In SQL Server, if I substitute the session.person.id for a known person Id and then run the code, it works fine....and if I substitute the variable for the same know person id in the eQL panel it works fine too.
    I've dug through some other queries that we have in eB and on Attribute Queries and they seem to recognise the $Session.Persion.id.......it's just my attempt that is failing.
    Thanks for your time on this...it's much appreciated.
    Paul
  • The code you are using is with SQL syntax and eQL syntax is totally different.
    So you cant transfer the same query to eQL. You need to change the syntax before query to eQL.
    Please let me know if you need help with eQL query.
    Manav B.
  • Thank Manav.....I know eQL is slightly different from normal SQL but most of the time it it follows the same syntax/structure etc....or, at least, that's what we have found on our more basic queries. I'm sure the more complex stuff would show up greater differences.
    However the query I sent works perfectly well except for the id variable that we are trying to sort out now. If I substitute $Session.Person.Id  with 3379, a known person.id the query works properly. So the code I'm using, up to the point of referencing the variable, must be okay mustn't it?
    Paul
  • Hi Paul,
    To use variable in it, you can do something like this: Declaring and setting the variable and using in SELECT.
    DECLARE @pi_object_id INT
    SET @pi_object_id = 1
    SELECT  * FROM tasks WITH(NOLOCK) WHERE task_id = @pi_object_id
    This is effectively doing
    SELECT  * FROM tasks WITH(NOLOCK) WHERE task_id = 1
    Manav B.
    Answer Verified By: Carma De Villiers
  • Hi Manav,
    Yes, I've tried that but the issue remains that you cannot SET the new @pi_object_id to the Session.Persion.Id........so the problem is exactly the same. If I set it to a known person_id e.g. 3379 then it works but not if I set it to $Session.Persion.Id.
    Maybe eB queries don't accept variables like this.
    Paul
