Projectwise Automatic File Registration
In eB 15.6 automatic projectwise file registration doesn't happen when the Projectwise connector is synchronised.
I have already tried excluding the folder, adding it again and resyncing as per the wiki posts on this site. And I know that all of the attributes on the PW documents are as required by the eB synchronisation options.
Everything in eB director ProjectWise Explorer and ProjectWise is set up correctly. The files are not already registered. When I register files individually they go across, it is only the automatic registration that doesn't work.
Is there an event that should be in the SMC that controls automatic registration? Or is there are stored procedure we may be missing?
Catherine
