please give me one or more samples in eB web for plugs framework? please !
Hi Kemo,Could you please explain little more about the use and requirement. Also when you say example for plugs framework, does that how to create plugins framework or use of eB Developer?
I was doing two times the development of eB web, the company to do OA system now, eB access and data management. Now do not know how to create the framework, how to access eB data. So they need an instance of insert frame access to eB objects based on Web, if I can be so just do business work.
Hello.
Excuse me, 1, operation: Start -> program ->Bentley->eB Deveploper->Visual studio Help->Add Visual studio 2010 Help,
2, the new project: The plug-in template and is available in Visual Studio 2010 when you use File Project in - > New - > the Visual C# section, under "Web" Enter a name for. The plug-in, eg "ReportPlugin" when creating the project and create the project. The plug-in contains some sample activities,I didn't see anything about Web Framework Plug-in Project Template.
in this process How do you see this template?
Good day, has this issues been resolved?
Answer Verified By: Carma De Villiers
