I'm trying add calculated mask onto a template, but it doesn't do it says something about I need Requires SQL function EB_EXTRACT_CALC_MASK to be loaded, see SQL sheet but when I look in the SQL sheet I don't see any query in there about Cal_Mask. I can't manually edit the template to add it either can you help please?
Hi, could you please send me ships of the steps you took to set up your calculated mask. Please send all with the error message as well. I have tested and do not get the same error.
Answer Verified By: Carma De Villiers
