Hello everyone!I've stacked into a small problem with Publisher. We have Tags, each Tag has its own range of Documents, each Document may have or may not have attached files. If we select some Tags in Explorer and Publish these Tags we get an html page with report. Tag page contains the table with documents, but Documents names are not links, so, we can not go to Document's page and view the attributes of any Document. Below you can see the result of html generation for one document (one row in table Documents for Tag).
<tr> <td>Working documentation</td> <td>Document name</td> <td>Not Approved</td> <td>Draft</td> <td>Global</td> </tr>
Hello Potseluico, which Bentley product are you using?
We are using eB, version 16.4.2 - eB Director and also eB Web.
Hello Potseluico Anastasiya,
Can you tell us what eB version you are using ?
Hello!We are using eB, version 16.4.2 - eB Director and also eB Web.
Can you try to publish using CHM output format instead of html. I've tried on my back end and as in your case, HTML format publishes only headers of related objects. XML output format seems to work as expected and all data on objects gets extracted and xml structure is used when creating CHM file type output.
Answer Verified By: Carma De Villiers
