Hi
I have the storage queue that keeps on being disabled, i try to enable it via the smc but without it wanting to run.
The properties settings is also set on " Not Dissabled" on the community, so that is n order.
From the server manager the following is received.
eB.Service.Storage:
The queue for community 'STEINMULLER' has been disabled.
The local storage configuration for the server 'ZAJHBETB01' is invalid, this is likely because the community may have been updated but the local settings was not. Reconfigure the community for the storage server to fix the problem.
--- Begin of exception stack trace ---
at System.Environment.get_StackTrace()
at eB.Common.BaseException.ToString()
at eB.Diagnostics.EventLog.WriteEntry(String message, Exception ex, String applicationName, EventLogEntryType type)
at eB.Service.QueueProcessing.PollEventArgs.Disable(Exception ex)
at eB.Service.QueueProcessing.PollEventArgs.Suspend(Exception ex, Boolean disabledByJob)
at eB.Service.Storage.QueueEventHandler.ProcessQueueEntry(Object sender, PollEventArgs e)
at eB.Service.QueueProcessing.PollingService.TakeTurnThread.ThreadProc()
at System.Threading.ExecutionContext.runTryCode(Object userData)
at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ThreadHelper.ThreadStart()
--- End of exception stack trace ---This is not a valid session most probably because Logon was never called. Please ensure that you are logged on correctly.
Inner Exception: This is not a valid session most probably because Logon was never called. Please ensure that you are logged on correctly
Hello Dean,
Please try to disable Storage for this community by deselecting community from Storage and then adding it back.
Let us know how it goes.
No it did not work.
Here is the actual report on the problem from the management console in the storage Queue.
CPY
--- Begin of exception stack trace --- at System.Environment.get_StackTrace() at eB.Common.BaseException.ToString() at eB.Service.Storage.ServiceObject.Query(String communityGuid, Object additional) at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md, Object[] args, Object server, Int32 methodPtr, Boolean fExecuteInContext, Object[]& outArgs) at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg, Int32 methodPtr, Boolean fExecuteInContext) at System.Runtime.Remoting.Messaging.ServerObjectTerminatorSink.SyncProcessMessage(IMessage reqMsg) at System.Runtime.Remoting.Messaging.ServerContextTerminatorSink.SyncProcessMessage(IMessage reqMsg) at System.Runtime.Remoting.Channels.CrossContextChannel.SyncProcessMessageCallback(Object[] args) at System.Runtime.Remoting.Channels.ChannelServices.DispatchMessage(IServerChannelSinkStack sinkStack, IMessage msg, IMessage& replyMsg) at System.Runtime.Remoting.Channels.BinaryServerFormatterSink.ProcessMessage(IServerChannelSinkStack sinkStack, IMessage requestMsg, ITransportHeaders requestHeaders, Stream requestStream, IMessage& responseMsg, ITransportHeaders& responseHeaders, Stream& responseStream) at eB.Common.Net.PerformanceCounterServerSink.ProcessMessage(IServerChannelSinkStack sinkStack, IMessage requestMsg, ITransportHeaders requestHeaders, Stream requestStream, IMessage& responseMsg, ITransportHeaders& responseHeaders, Stream& responseStream) at System.Runtime.Remoting.Channels.Tcp.TcpServerTransportSink.ServiceRequest(Object state) at System.Runtime.Remoting.Channels.SocketHandler.ProcessRequestNow() at System.Runtime.Remoting.Channels.SocketHandler.BeginReadMessageCallback(IAsyncResult ar) at System.Net.LazyAsyncResult.Complete(IntPtr userToken) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Net.ContextAwareResult.Complete(IntPtr userToken) at System.Net.LazyAsyncResult.ProtectedInvokeCallback(Object result, IntPtr userToken) at System.Net.Sockets.BaseOverlappedAsyncResult.CompletionPortCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* nativeOverlapped) at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP)--- End of exception stack trace ---This is not a valid session most probably because Logon was never called. Please ensure that you are logged on correctly.
--- Begin of exception stack trace --- at System.Environment.get_StackTrace() at eB.Common.BaseException.ToString() at eB.Common.BaseException.ToString() at eB.Service.Storage.ServiceObject.Query(String communityGuid, Object additional) at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md, Object[] args, Object server, Int32 methodPtr, Boolean fExecuteInContext, Object[]& outArgs) at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg, Int32 methodPtr, Boolean fExecuteInContext) at System.Runtime.Remoting.Messaging.ServerObjectTerminatorSink.SyncProcessMessage(IMessage reqMsg) at System.Runtime.Remoting.Messaging.ServerContextTerminatorSink.SyncProcessMessage(IMessage reqMsg) at System.Runtime.Remoting.Channels.CrossContextChannel.SyncProcessMessageCallback(Object[] args) at System.Runtime.Remoting.Channels.ChannelServices.DispatchMessage(IServerChannelSinkStack sinkStack, IMessage msg, IMessage& replyMsg) at System.Runtime.Remoting.Channels.BinaryServerFormatterSink.ProcessMessage(IServerChannelSinkStack sinkStack, IMessage requestMsg, ITransportHeaders requestHeaders, Stream requestStream, IMessage& responseMsg, ITransportHeaders& responseHeaders, Stream& responseStream) at eB.Common.Net.PerformanceCounterServerSink.ProcessMessage(IServerChannelSinkStack sinkStack, IMessage requestMsg, ITransportHeaders requestHeaders, Stream requestStream, IMessage& responseMsg, ITransportHeaders& responseHeaders, Stream& responseStream) at System.Runtime.Remoting.Channels.Tcp.TcpServerTransportSink.ServiceRequest(Object state) at System.Runtime.Remoting.Channels.SocketHandler.ProcessRequestNow() at System.Runtime.Remoting.Channels.SocketHandler.BeginReadMessageCallback(IAsyncResult ar) at System.Net.LazyAsyncResult.Complete(IntPtr userToken) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Net.ContextAwareResult.Complete(IntPtr userToken) at System.Net.LazyAsyncResult.ProtectedInvokeCallback(Object result, IntPtr userToken) at System.Net.Sockets.BaseOverlappedAsyncResult.CompletionPortCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* nativeOverlapped) at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP)--- End of exception stack trace ---
