Hi Team,
We have recently upgraded EB form 15.4 to 15.6 and this caused an errors that seems to be common after upgrade. Clicking on EB generated E-mail link or at Check out , Give the error message attached : "The link you have followed refers to a different community than the one that you are logged in to.." . We are basically getting the same error message as mentioned in the links below even though the Data source and the community have the same name. I read through the work around but is there and fix for this bug please?
Here are the links that I checked
https://communities.bentley.com/products/assetwise/assetwise_platform/f/eb-assetwise-alim---forum/100750/change-the-active-community-error
https://communities.bentley.com/products/assetwise/assetwise_platform/f/eb-assetwise-alim---forum/104215/problem-opening-a-link-from-e-mails-sent-from-eb-web-15-6-1
Hello Stephane,
Are you getting these errors from links which were created before upgrade or these links are created after upgrade?
CheersGintautas
Hi Stephane, has this issue been resolved?
Answer Verified By: Carma De Villiers
Hi Carma,
This still affects us but we have lived with it. is there any update on it please? is a bug?
Cheers,
Julie
Hi Julie,
Best will be to upgrade and run the scripts. they will not fix any of the older versions now as version 16.7 has already been released
