Hello Support,
Need a small information with in eB. Is there any way to find out the Hard coded / un encrypted passwords of eB?
Hi Lucky,I am afraid, there is no way to find out the in-encrypted password. If you want to you can change it default for Admin, but that too is encrypted string you need to run on Database table.
Hello manav,
Actually somewhere in the XML files i have seen that we can edit the user name and the passwords. Is it in the Web Config file or any other? I am not sure.. Just Asking
Hi Lucky,
There is no way to decrypt the password any where.You must have seen it in way older version where the encryption was not updated.
Now, all the versions are with encrypted password and it is designed to hide the actual password from all the locations.
Answer Verified By: Carma De Villiers
