Hi Everyone
Can someone tell me if the eB Provisioning sheet v16_4_2 will work on ALIM v16.6.2
Hello Jurie,
It would not work as there may be fixes done in 16.6.2. While testing this needs to make sure that the xml mapping is correct and engines that imports the objects as well.
It may vary version to version
Priyanka
thx, Do you when the new eB Provisioning sheet for ALIM v16.6.2 be available?
Hi Jurie, I have asked if you may receive the provision sheet and awaiting feedback. Will let you know as soon as an answer has been received
Hi Jurie, unfortunately we are not allowed to supply you with the document. PS will have to assist with the import. Could you please speak to Natasha to assist with this.
There is no such thing as provisioning sheets from v16.6 onwards. The provisioning sheets that we used to use simply don’t function in v16.6 onwards.
There is now a bulk import export tool that can be run by either the PS team or the client (usually an admin).
The bulk import export tool needs an xml configuration file. An example is delivered as part of the installation.
The example matches the configuration necessary to provision the system as we used to do in past versions.
What the client do with that xml configuration is up to them, but it is part of their installation and can be used by them.
However, I would recommend they understand how to create their own configuration files for their own particular use cases… not just use a massive provisioning configuration which is complex to understand.
Olly
Answer Verified By: Carma De Villiers
