Hi
We currently use the email distribuition tool and seem to have some problems with content being in the transmittal sections which is not listed in my basket.
I need to know how i can remove that as this is troublesome to remove or deselect these objects everytime i do a distribution.
Please see attachement.
Thank you
Hi Dean,Not sure if I understood your question correctly, but what I think When you select the main object from the Basket hierarchy as Document, it will automatically select all the sub objects under it. If you want to select few out of all, you need to expand and select manually. Also, as it is a customization tool and above information is not helpful for you, you have to contact professional service person who worked on it.Thanks,Manav
Hi Dean, has this issue been resolved?
Answer Verified By: Carma De Villiers
