Hi
When i do a search in eB (15.6.1) for a specific range of documents and do an export to excel it always gives 2 document status columns. how can i correct that?
Thank you
Hello Dean,
Can you specify name of column ? are they same?
The list two status "Approval status" and "Document status", they both are different
Priyanka
Hi Priyanka
Yes there is 2 identical columns.
"Document status"
Do you get the same repeated column in eB web search results also ?
Below is a Core Document Search export from version 15.6. Your export also contains Status column which is not in core search element. This leads me to think that you are using custom search. Please check eql code of this search for duplicate elements under Select statement.
Hi Dean, has this issue been resolved?
Answer Verified By: Carma De Villiers
