The 16.4.2 provisioning sheet does not seem to allow multiple folders to be created with the same name even though they have different parent folders. Is there a fix or workaround for that?
I have tested on Director and can do it on Director. Are you using Web for this or Director?
Also tested in Web and no issue. I have tested this not using the provisioning sheet, so there might be an issue with the sheet. Could you please send me your provisioning sheet in order to check
Yes. The problem is only with the provisioning sheet. When it looks for an existing folder it only looks for one with the same name, not one in the same parent folder with the same name. As you pointed out, this is supported in the application front end. I just wanted to know if anyone had run into this and had a fix or workaround for it.
Will get back to you soon. Let me make sure about a work around
Provisioning Spreadsheet.zip
Please try this provision sheet and see if it solves the issue
