Is there a ALIM version where this techology is available or planned?
I would like to identify our assets (TAGs, Ph Items) by use of a QR code and gather information of them by the use of those QR codes.
Patrick, you can use any code that you require. Create a template with the required code and use that to create your Physical Item and Tag
I mean how can it be integrated into eB?
Scan QR code and get the right eB asset information of it by a mobile device.
Hi Patrick, it can be done if someone writes you a script to do this. You will have to contact your account manager and request that Bentley Professional Services write you a script. This will involve a cost. This will be a customization
Answer Verified By: Carma De Villiers
