I just install eB v16.7.9 with environment of VM, WinServer2016, SQL2016. And create community successful, I can do config with default ADMIN account. But when I login Director, it show the message "You don't have permission to see the 'System' folder" on 'Explore' pane, also "You don't have permission to see the 'Information Modeling, ' folder."
After refresh the Error message as below:
An invalid [negative] pi_object_type was passed to ebpnew_get_explode.Exception Stack Trace:{--- Begin of exception stack trace ---System.ServiceModel.FaultException: An invalid [negative] pi_object_type was passed to ebpnew_get_explode.Server stack trace: 在 System.ServiceModel.Channels.ServiceChannel.HandleReply(ProxyOperationRuntime operation, ProxyRpc& rpc) 在 System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout) 在 System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation) 在 System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message)Exception rethrown at [0]: 在 eB.Service.ClientBase`1.IfRemotingErrorThenRetry(Exception ex, Int32 retryNumber) 在 eB.Service.ClientBase`1.ExecuteAction[TResult](Func`1 func) 在 eB.Service.DataReaderClient.Retrieve(RetrieveRequest request) 在 eB.Data.BaseObject.Retrieve(Int32 id, Int32 type, String options) 在 eB.Application.DataAdministrator.SysAdminExplorer.ObjTreeNode.GetExplodeNext(Int32 objectId, Int32 objectType, Int32 options, Boolean isManufacturerTree, Boolean isRefreshCall) 在 eB.Application.DataAdministrator.SysAdminExplorer.ObjTreeNode.ExpandNodeNext(Boolean isRefresh)--- End of exception stack trace ---}
Have I forgotton anything to set ?
Hi Jerry, as whom are you logging in. Can you log in with the Admin credentials?
Hi Carma, there was only Admin account can loggin. Scripts just run on the database so it was an empty system.
Did you now populate the system and add users and permissions? You will only be able to see if you can log in with different credentials once all has been populated or a backup has been installed. Please let me know what you are doing. Thanjs
Any feedback on this?
I'm sorry for the late reply. I mean in v15.6, after creating community I can login with ADMIN credentials and create classes or relationship or other user account. But the same way in v16.7 there was a permission problem.
It wasn't a backup. I created a new database and community for test. Anyone else happened before?
