Unable to open eB Historic files
When you checkout a document and check it back in the system will create a backup of the file in the Copies object.
By default the file created maintains its original name but has (eB Historic 001) appended.
This is all fine up until someone wants to open it however when they do they get the following message:
“Could not launch the file *****, your computer does not seem to have a program that can open it.”
This is because true file extension is now obscured by the (eB Historic 001) label.
Is there any way to change this?
