installing ActiveX control manually with limited access - Need Media File and Instruction to Install ActiveX control manually necessary for eB
We have few users in one organization with limited access and to use they need to have ActiveX control installed but due to limited access ActiveX control is not getting installed which is required for eB. When I talked to their IT department, they recommended a media file with instruction to install ActiveX control manually. In this regard I was wondering if we can get the media of ActiveX control with instruction to install it manually.
Vikash
