eQL report to show Document Owner and Author on the same line
Is it possible to create an eQL report that will show Owner and Author of a document on the same line?
The query below shows the Owner and Author on separate lines, thus duplicating the the document number:
START WITH Document
SELECT
   Id,
   Code,
   Name,
   Revision,
   Responsibilities.Person.FirstName + ' ' + Responsibilities.Person.Surname Responsibility,
   Responsibilities.ResponsibilityType.Id IDRespon,
   Responsibilities.ResponsibilityType.Name NRespon
WHERE
      Code LIKE @code
      OR @code IS NULL
   AND IsTemplate = 'N'
   AND        (
          Responsibilities.ResponsibilityType.Id = 2
          OR Responsibilities.ResponsibilityType.Id = 9
ORDER BY
   Code,
   Revision
Result:
Result
The result I'm trying to get is this:
Desired Result
