We are upgrading from v15.6.1HF396 running on SQL Server 2008 to v16.7.2 running on SQL Server 2016SP2. We already have a v16.7.2 brand new community up and running fine, almost empty that we created before moving real communities, just for testing purposes.
The error is shown after Datasource creation in v16 SMC and the system detects an old database version and ask to run upgrade scripts. We click yes and the we receive the following error:
We have check everything, we have re-run upgrade and maintenance scripts from v15 SMC, stopped the eB service, stopped the eB Package and move again the database from SQL Server 2008 to SQL Server 2016SP2, but the error persists. Do you have any idea whats is going on? This is the error logged at SMC:
# Database update log
# Application Server Version : 16.7.20.9 Release
# Database Name : FANTASYDBNAME
# Database Server Name : FANTASYSERVERNAME
# DBMS Name : Microsoft SQL Server 2016
# DBMS Version : 13.00.5026
# Package name : Core
# Date : lunes, 6 de mayo de 2019
# Time : 17:24:55
# Current Core Database Version : 15.6.1
# New Core Database Version : 16.1.1
# Package file : C:\Program Files\Bentley\eB\Server\Database\Core.16.1.1.Mssql.zip
Error while updating the database, An update is already in progress for this database. Wait until it completes then try again.
** Log file closed on lunes, 6 de mayo de 2019 at 17:24:55
Thanks in advance, kind regards,
Sebastian.
Hi Sebastian,
I know you are following correct steps just to make sure can you please check the below link and confirm.
https://communities.bentley.com/products/assetwise/assetwise_platform/w/wiki/40684/to-upgrade-the-datasource-database-from-eb-15-xx-to-eb-16-xx
Also check the link and let us know the status of database upgrade in back end just for confirmation.
https://communities.bentley.com/products/assetwise/assetwise_platform/w/wiki/39116/director-login-error-the-database-is-currently-being-upgraded-please-try-to-login-again-in-a-few-moments
Please let us know the findings and share the screenshots. There is already a defect filed for this kind of issue, but for the different version attaching the link for reference.
https://communities.bentley.com/products/assetwise/assetwise_platform/w/wiki/23591/database-upgrade-error---an-update-is-already-in-progress-for-this-database
Sayyad
Answer Verified By: Sebastian Fernandez Pacheco
Thanks Sayyad, we'll proceed step by step following the links and get back to you, kind regards,
Hi Sayyad, It worked like a charmed! Thanks a lot, kind regards,
