Hi Team,
I have a question regarding EQL query reports in eB.
We have a code which has lines around 4700+ which is like almost 4675 options in where clause. While i'm running this our eB is not responding. Am i missing something or we can't run 4700 lined query in eB reporting.
Help will be appreciated.
Sateesh.
Hi Sateesh,
I think where clause might be a problem here. Just a suggestion. Copy the same code and test it using nearly 10 Where clauses not more than that and let us know the results.
Sayyad
Hi Sayyad,
Thanks for the response.
Yeah that way its working earlier also but I just want to confirm if there is a working way with over 5000 where clauses.
Actually, we have not tested any eQL report with these many where clauses. Can you give us the eQL query you are running.
Also when you were building this query, you received any error or warning messages from eQL builder. like the below one:
Hello Sateesh,
Are you still facing the issue? If yes, can you provide the EQL query?
Padma.
