I made changes to the layout editor to add a new field. Is there a way to get this new field to show up on the Web for objects that were created prior to this change, but not approved yet?
Hello Lisa,
New attributes will be applicable to all the classes/templates that you have inherited while creating the attribute in eB Director. But you will be able to edit them from eB Director only. Once the value is provided you will be able to see the attribute and its value in eB Web and can now edit from eB Web itself.
Nikhil Gumaste
Answer Verified By: Lisa Becker
