I'm trying to reduce the size of my SELECTServer database. Currently its15GB which is unacceptable. I've turned on the data retention and set if 6 months but this did not see much of reduction in size. After closer inspection there are two tables which accountable for about 95% of space:
ss_xx_NightlyProcessingHistory
ss_xx_NightlyProcessingHistoryDetails
These contain data from the very beginning ~2015 and contains millions of rows. Is it safe to delete data form these tables?
Hello Andy,
These are not eB tables, can you talk to you local or Internal IT team? Unfortunately, we cannot help you with this!
Padma.
