Good morning,
I only have a limited view of the relationships tab/s, which makes it difficult to work with (delete. etc), especially the Virtual item tab. Some viewers can't see the tab at all.
It's probably a display setting, please assist.
Thank you
Hello Jeanne,
Can you please try below:
1.Close all browsers
2.Clear cache
3.Re-open eB and try again if you can see the Relationships
There can be many reasons for it to happen.
Padma.
Hi Padma,
Thank you for the reply.
Will the solution you suggested be applicable to eB web or the application? I'm using the application.
Which cache should be cleared?
Kind Regards,
Jeanné
It will be applicable to both web and Director.
Also, please minimize the Revision history report tab and try opening one tab at a time, you will be able to see.
Ignore my comments for clearing cache.
Hi Padmra,
Evedn with all the tabs minimized it still doesn't make a difference..
I'm also having trouble displaying this item. You share easy steps to self-adjust. mini crossword
