I would like to add more for project status. I want to add ACTIVE and DEFERRED
Hi Lorato,Status is hard coded and there is logic built around the values coming from database table. If it is just an attribute with fixed value drop down list, you can easily modify or add some values.But I am afraid, Property value is limited with eB Director and not advised to update the values from backend.
Hi,I'm getting "value is out of range" error.Can I only change the status name? Is the set of Document status values predefined?
communities.bentley.com/products/assetwise/assetwise_platform/replace-value-with-y-or-n essaydune.com
