Dear Team,
When typing in the class of the document even though the abbreviation for document code is correct, eB (ALIM) tends to freeze.
Version 15.6.1
Thank you
Hi Dean,
Can you share a screenshot of this issue.
Regads,
Sayyad
Hello Dean,
After you type the abbreviation, could you please press downward arrow key from keyboard and check if it does give you code?
Priyanka
I cannot send you a screenshot of director when it freezes. basically it is when you manually type the class then it freezes in some instances.
Dear Priyanka,
I have tried this and although I type in the class manually and press down arrow it still freezes. you have to physically use the class lookup.
