Dear Team,
I want to create an eQL report in 15.6.1 Director to show what documents was created by a user for a specific period of time (I need to be able to specify the dates in the query) then in the results I want the report to include the attributes for the document as well. ( as an example if I have a net value in my document attribute it must show the column "net value" along with the added value) This report will assist by showing the amount of documents created by a user.
Thank you
Hi Dean, can you add it via the Attributes node on the right hand side in your query? It should be something like:
Attributes["Global", "NetValue"].Value
depending on the name of the attribute and your scope.
Cheers,
Julie
