Hello There,
I need a small information. Is there any way to add multiple users in eB in single go? Let me explain clearly. we have 3 different scopes. sometimes we may need to add multiple users say 50 users with same roles and skills in a particular scope. Sometimes we may need to add multiple persons with same roles and skills in multiple scopes. So to save the time and efforts, we are looking for an option to add the users from AD to eB with the desired roles and skills. So please suggest us, Is there any way to add the users from active directory to eB as per our requirement? Many thanks in advance.
Hello Can someone help me in this???
Hello Lucky,
There is option to create users from AD and this can be set in SMC (see screenshot below), but to my understanding you would be using 3 different template with different configuration for creation of these users. If you are in eB V16 there is standard import/export tool called ALIM Import Export application. Using this application you would be able importing users, assigning roles and skills. Let me know what version you are on so we could proceed with this.
Cheers
GIntautas
Hello Gintautas, We are using eB version (150601115). Is it having that import/export feature??
Hello, Unfortunately version 15 does not have a tool for this. There is custom tool that has been used by PS team, but it's not official and it's not supported as it might corrupt data. To get this tool you will need check with your account manager and raise this question with PS team
Okay.. thanks for your help.. I have one more question. suppose we already had some users in eB and have the access to one scope say A. we have 3 scopes i.e. A,B and c. suppose if I want to give the access for scopes B and c for the multiple users who are already there in the other scope, is there any way to give the access to all the required people in Bulk? sometimes we need to give the similar access to multiple people. everytime searching for the user and assigning the roles using the drag and drop is a very time consuming work. so please help me to find, Is there any option in eB to provide the access in bulk to multiple users (who are already there in other scopes).?? Thanks in advance.
