Hello, I work for Network rail where we hold data files, when I try to log in I get following error log. "Cannot insert duplicate key row in object 'dbo.objects' with unique index 'objects_ak1'. The duplicate key value is (f53b6e12-cccc-40db-9efd-4544b472d909, 1). The statement has been terminated."
Correlation code: 00236e5f-629a-46a2-bfbd-705550667440
Hello
What version of eB you are using and have you switched your login between user recently ?
thank you for your reply
16.7.24.42 I believe
Please do raise Service Request as will require access and investigation of DB.
Thank you
I tried that and they sent me to this forum.
Could you tell me SR number. I will reopen if it was closed and will assign it to myself.
