We have an install of eB 15.6 which is returning an error when trying to update the Default Navigator, but we're not sure what the error is trying to tell us. We get this error for all users, including the Admin account. On a different community, set up similarly, the functionality works but not sure where to investigate if the Admin account won't apply the update.
Any help much appreciated - many thanks,
James.
I can replicate this as well James and Gintautas (for the affected v15.6 instance, as I have access to it). Nothing comes back from that search Gintautas
We have run this in both the community we are experiencing the problem and another without the issue and we get no results both times.
Have re-run using the ADMIN account on both communities and no results returned.
We (Julie) found that this was caused by having no default organisation set further up in the settings - once we rectified this, we were able to update the fields we wanted.
Many thanks for your help on this.
