did the update from the connection client on Monday, following the update MicroStation Connect has taken an age to open, and has thrown up a couple of error messages when opening. it does open eventually and works fine but prior to doing the update on Monday AM everything was fine and no errors etc.. ?
Error in DB Script at line: 492code = Error (1), message= System.Data.SQLiteException (0x80007BF); SQL logic error Duplicate column name UseNamedAccessKey
At
Bentley.Cloud.Thock.DatabaseU[grade’1.ExecutiveSqlStatement(TConnection,StringBuilder sb, Int32& statementsExecuted, Int32 totalExecutableStatements) at Bentley.Cloud.ThickClient.Database.DatabaseUpgrade’1.RunScript(Object parameters
Command in Error:
ALTER TABLE [Policy] ADD COLUMN [UseNamedAccessKey] nvarchar DEFAULT ‘’ NOT NULL
also another error message
Unable to start ''MicroStation''.
Licencing service failed with error code -2. Please contact your local site Administrator for further assistance.
Anyone got any ideas ?
Ross
