How to access an obsolete drawing whos status is 'Historic'. They are not coming up in the normal document search results.
Hello Devang,
Which version of ALIM you are using? When you do Advanced search, there is option to choose Historic document for document status.
Hope this helps.
Priyanka Kale
Answer Verified By: Devang Singh
Thanx. When I was searching before the result was not showing up but now for some reason they are so its working now I guess.
