I'm able to retrieve all the necessary fields for Files in eQL (File name, size, page, type, etc.), but the only one I can't find is the "Description" field of a file as I want to show the Description field of multiple Files inside a Document in a search result. Is it possible in eQL?
eB version 16.7.25
If starting with the File object type, the value you are looking for is the Copies.Description.
Answer Verified By: Raphael Cardin
