I'm using the "Attribute Bulk Update" to update all the attributes of drawing that I am migrating into ProjectWise. It is setup to read a specific Tag Set within each drawing to fill in the attributes. It has worked flawlessly for 1,000's of drawing but this last time it keeps messing them up. I can't figure out where the issue is. I've gone through the drawings and I can't find anything that has changes or is different. I've used the same process as I did on all the previous drawings.
I'll attach a screenshot of what it does and what they are supposed to look like. First one is of CAD file after I upload into ProjectWise. Second is of CAD file After I run "Attribute Bulk Update" and view the properties within ProjectWise. Third one is of the Rendition I create after running the Attribute update program.
Hi David,It looks like an Projectwise query. Could you please use below link to post all your projectwise related questions:https://communities.bentley.com/products/projectwise/content_management/
Hi David,As I replied earlier, it looks like an Projectwise query.
